disable snmp authentication-trapsNEW!
Description
Prevents SNMP authentication traps from being sent from the switch.
Syntax Description
Default
N/A.
Usage Guidelines
This command does not clear the SNMP authentication trap receivers that have been configured. The command prevents SNMP authentication traps from being sent from the switch even if authentication trap receivers are configured.
To view if SNMP authentication traps are being sent from the switch, use the show management command. The show management command displays information about the switch including the enabled/disabled state of SNMP authentication traps being sent.
The following command prevents SNMP authentication traps from being sent from the switch to the trap receivers:
This command was first available in version 33.1.1.
Platform Availability
